Aggressive1
- Apr 19, 2005
- Myrtle Beach
I run this idea through my head about once a month and just think...someday I will find a way....but not worth the trouble right now.
I am running a 9" rear and just swapped in a second one to build my suspension off of. So......I have a spare 9" housing here to play with that has TJ brackets welded on the tubes, so to do a custom suspension on it is too much work. So tubes would have to be cut and replaced. I am running a D44 front out of a 79 F100 that has the cast c's. I had no problem building brackets to work around the cast c's since they were cast steel and I could weld to them. But the set up is not pretty. Works well, but I want it to LOOK like it works well (by the way, that was my first fabrication job).
But I really wanna use a 9" center section up front (just because). So....I know its been done many times, but has anybody HERE done it using say 44 shafts (since I just got in superior chromoly shafts for the 9") and maybe chevy dana 60 outter knuckles for the flat tops and dana 44 1/2 ton brakes, etc. for the 5 on 5.5 lug patter? So basically, I see the hardest part is matching up the right inner c's and maybe retubing with new tube?
