justjeepin86
- Jul 9, 2005
- Winston-Salem, NC
so what's everyone running for 9" disc brakes. Looking to go to them and curious what everyone is doing.
michael
michael
I know several people that won't go back to drums.Almost everyone I have seen that puts the rear disks on takes them back off shortly thereafter. You DO NEED an E brake and the caddy caliper ebrake seems to suck. The best way to go is with something simular to the currie set up which is an explorer disk with drum e brake. Why do you want disks anyhow?? The drums have better holding power anyways. Especially helpful for really low gears as disks wont hold good. I've seen many with crawler t cases swap the front axle to drums for the better holding power. SB
I guess this is why most all new car/truck manufactures use discs....they just don't know any better.Almost everyone I have seen that puts the rear disks on takes them back off shortly thereafter. You DO NEED an E brake and the caddy caliper ebrake seems to suck. The best way to go is with something simular to the currie set up which is an explorer disk with drum e brake. Why do you want disks anyhow?? The drums have better holding power anyways. Especially helpful for really low gears as disks wont hold good. I've seen many with crawler t cases swap the front axle to drums for the better holding power. SB
As to more holding power, wow, I mean other than the physics being totally wrong you are spot on. I mean really, how much do physicist no about coeeficients of friction anyway?
Some people will argue that if discs are so great, why would big rigs still use drums. .
The simple reason they are not used in the US is that American trucking companys don't like to change unless they are made to by the government.
Volvo is working on disc brakes for when this happens, and we have one truck outfitted with them at the design center here in Greensboro.
Search newbiepics please
