Jeepjunky87
Member
- Aug 4, 2013
- N. Raleigh
Does anyone have any info on converting a ford 9" rear end into a front axle with steering? Any ZJ guys done this? Or 8.8?? I can put my hands on both....
It can easily be done, but not for less than the cost of a Dana 60…
All depends if you're going to do chromoly shafts, locker and gears in the 60. That's easily $2k, both axles will need brackets welded on. Finding a f250 front d50 and using the inner c's (they are the same as ball joint 60 C's) then take a junk yard 9inch housing. Might be able to even reuse the tubes from the f250 since is going under a ZJ. You have to get creative and be pretty competent with fabbing to do it. You could probably do it and have gears lockers and maybe even chromo shafts for $1500.
And then you break the pinion support.
The 9" is a great diff, but you can spend over $1500 just making the third reliable.
It could be a laundry list, all depending on tire size usage, driving style.
No, not exactly. Your grandma could break a stock 9" chunk. It really just comes down to bad luck.
Oh, and since we're talking 'budget' swaps, I'm assuming a high pinion third is off the table. In that case, don't forget about the $500 driveshaft that you'll need to reach the 9" pinion way down there in the dirt.
For the record, that's the curry high pinion 9". The "hi nine" by truehi9 is virtually the same as a high end 9" center section just with reverse cut gears.paradisepwoffroad has a "609" for sale. PM him!.
Yes... know the "hi-nines" aren't really 9" ring and pinions. They are 8.8 ring and pinions, which have no pinion support.
I would recommend getting a nodular iron pig. I built a hi-nine in a rear that has been mercilessly abused for a couple of years with 38" tires with no issues.
And while we're correcting the record, it's CurrieFor the record, that's the curry high pinion 9". The "hi nine" by truehi9 is virtually the same as a high end 9" center section just with reverse cut gears.
