Ford 9 w/ 8.8 disc brakes??
03Rubi
Member
Maiden
I have a Ford 9in with drums that I wanna go disc brakes on, I have heard that entire brake setup from an 8.8 will basically bolt right on, any truth in this? plus....
If it is a direct fit which 8.8s had the e-brake made into the caliper and not a separate smaller drum strictly for the e-brake inside the disc, I think the mustangs had this setup, any others?? Looking for a cheap setup here
Thanks!
After looking at the chart it doesn't look good for no mods. I'm sure you could modify the 8.8 backing plate to bolt up.
Sent from my iPhone using Tapatalk 2
I have not done it, but I have had all the parts in-hand at one time. The 9" was off a late 70's pickup, which is the same big-bearing housing. It is not a direct swap.
