- Mar 10, 2005
- Hooterville (24171)
'91 5.0HO w/ factory everything (Mustang if it matters?)... pressure washed the engine on Sunday to remove 20 years of gunk. She fired right back up, so I backed it into the garage & shut it down (didn't want to warm the garage back up to 120*
) An hour later, went to fire it up and got nothing but clicking relay (inner fender). I'd had the interior light on for that hour, thought I'd drained the battery a bit, so put in the charger overnight. Monday AM had NO power to anything (no lights, fuelpump, etc)...
Confirmed 12V at ALL points using battery -, body, & block grounds (no DC amp meter):
- Battery = 12.6VDC
- Hot lug of relay = 12.6VDC
- "S" terminal & starter lug = 12.3VDC while in the crank position or jumping to "S"
- ALL connections from battery to relay are clean & tight
Now, when key is in the "start" position, I get a single light click on the relay. continue to get the 12.3VDC at "S" & starter lug. When key goes back to "run" position, no voltage on "S", BUT still read about 6-7VDC on the starter lug!
It will stay this way (latched, low voltage to starter cable, but nothing smokes or gets hot) until I remove power by yanking one of the battery cables. At that point, the relay will "open" and when power is re-applied, will have poer to lights & FP spins up in "run". "Start" gets the single click and we're back to the beginning...
Also, if I jump the relay (huge C-wrench) across the hot/starter lugs, I get a very light spark, but no starter action...
While I probably should replace both relay & "BIG" starter (IIRC, they went to a "mini-starter" in '92-'93?) now after 160K miles, I don't want to throw parts at it...
Between the relay appearing to function fine (except for the low voltage "latch") and jumping the relay giving me nada, I believe it's likely either the large factory starter wire, connection to the starter, or the starter? Haven't tried frapping the starter w/ BFH yet...
Hoping to get some consensus or additional troubleshooting info!
) An hour later, went to fire it up and got nothing but clicking relay (inner fender). I'd had the interior light on for that hour, thought I'd drained the battery a bit, so put in the charger overnight. Monday AM had NO power to anything (no lights, fuelpump, etc)... Confirmed 12V at ALL points using battery -, body, & block grounds (no DC amp meter):
- Battery = 12.6VDC
It will stay this way (latched, low voltage to starter cable, but nothing smokes or gets hot) until I remove power by yanking one of the battery cables. At that point, the relay will "open" and when power is re-applied, will have poer to lights & FP spins up in "run". "Start" gets the single click and we're back to the beginning...Also, if I jump the relay (huge C-wrench) across the hot/starter lugs, I get a very light spark, but no starter action...
