OBX Fisherman
- Mar 21, 2005
- Winston-Salem
I have a terrible oil leak on the front axle of this 85 yoto truck. I ordered a knuckle rebuild kit for it and finally started on it this week. Yesterday I got the knuckle off and in the greese around the birfiled I found these rollers from a bearing!
As you can see a couple of those got wedged between the housing and the birfiled. Here's a pic of the housing where you can see the marks.
Here's a pic of the birfield with marks from those rollers. I guess the flat spot on the birfiled allowed the roller to get piched in there.
The bearings in the top and bottom of the knuckle for turning were not missing rollers. My guess is at some point one of them disintegrated and the previous owner never tore down the knuckle to replace everything and clean it out. I even found that the steering arm is missing one of the 4 tapered washers/ nuts that hold it on!!
When I took the hub off I found the washer between the spindel nuts and the outer bering looks like this:
It looks like to me that the bearing might have spun at some point and scored the washer.
Now for a question, do you use a special grease for the birfiled thats different from the axle bearing grease?
Thanks
Gary
Thanks
Gary
