03 wrangler rubicon, 41/2" rubicon short arm lift, 33" tires
acts fint at highway speeds, however small bump in road causes violent side to side movement until I slow down. Just bought the jeep, what to do
as the above poster said...there are endless possibilities for death wobble...
first thing I'd do is try the "free" fixes...tighten the trackbar (loose lower bolt was the cause for mine), make sure the control arms are tight...and a visual inspection to make sure nothing is obviously bent...
control arm bushings could be a culprit, but hopefully an '03 doesn't have that issue...alignment would probably be next on my list...
