TPoindexter
- Sep 3, 2008
- Davie County
Ok did a spring over on my YJ with Stock springs. This replaced a black diamond 4 inch lift that was on it when I bought it. I left the transfer case drop and had good luck with factory driveshaft on the road. I have used it all hunting season off road and have a good leak on transfer case output seal. Trying to go low buck. Will the XJ driveshaft work if I cut it down or go ahead and do SYE. The reason behind being cheap is this is not the final driveline for the jeep but its a DD right now. I have a ax-15/231 combo. Just don't know what motor I am going with or just use a Dakota bell housing behind the 4 angry squirrels.
