Nissan11
- Nov 29, 2005
- Marston, NC
Ive got an 02 v6 frontier with a yellow top battery. This morning my truck started up like normal.
I made the 20 min drive to work and cut the truck off and went inside. I came out 25 minutes later, turned the key in my truck and heard a series of fast clicks. I checked the voltage of the battery straight from the posts, 10v.
I got a work truck, hooked up jumper cables and it started right up. I drove it about 30 min and cut it off but it wouldn't start again.
When the truck was running the battery posts read 13.5v on my meter. I got another jump start and on my way home I stopped and picked up new cables and terminals. I changed them when I got back.
The battery read 9.8v and wouldn't start. I got another jump and tested the battery again after it ran for 30 minutes, it showed 13.5v
I checked the voltage at the starter and it reads the same with the truck running.
Continuity between the cables and posts reads 0.
What the heck could my problem be? Is there anything else I can check with my multi tester?
