Loganwayne
#BTL
- Feb 15, 2013
- Clyde, North Carolina
First my whole house is on a crawl space besides my basement.
All the plumbing works in my house.
My washer/dryer is in the garage. It has been around 40 degrees during the cold spell but washer is up against two exterior block/brick walls. The drain line for the washer froze about 3,4 days ago (the plastic line from washer to hard drain line), I got it thawed and finished a load of laundry without a problem. Today I went to do a load of laundry checked the washer drain line first it was semi frozen but pushed water out no problem, so started the washer. Now the hardline isn’t letting any water threw, im assuming this line is frozen now. To me it seems strange that this line was fine a couple days ago but now is frozen. This pipe runs under the slab into the crawl space, it looks like it was the only pipe not replaced when the plumbing was redone so it is cast or galvanized. It seems weird that this line would freeze because it runs threw the middle of the slab, I guess it could have froze due to it being near the edge of the slab. Any other thoughts
