Looking to get a full size bronco soon and transfering some parts from my last build. Looking anywhere in the range from 1980-96, year isnt specific to body because I can always put the front clip I like on and plan to go to overfenders to clear 40s. My question is regarding transmissions and axle ratios. I intend to run an automatic and the 3 autos in these broncos are the c6, AOD and E4OD. I've heard the AOD just womt handle the abuse and to avoid it like the plague. I'm wanting to run a doubler if possible and length will allow. I know the E4OD is longer than the c6 so I'm not sure if it's too long to use a doubler and at 3.73 gears on 40s I'm certain I'll have to regear to 5.13 (the deepest I've found for the sterling) sooner rather than later to keep the trans alive. The c6 though is shorter and can fit a doubler as well as run with my current 3.73 gears, but I feel like I'm going to have a much shittier gear selection running such a high gear offroad. Anybody have some real life experience of why one trans is obviously the better choice and why I should run it. Or real world experience running a doubler with the e4od in a bronco?
