Fuel cell install help
4x4yj
Just picked up a 2161a and added some walbro pickups.
Will the stock fuel cell gm sending unit work with my yj fuel gauge?
Anything else need to be done other than wiring up an external fuel pump of my choice?
That sender will not work with your factory gauge. I dont know that you will find a sending unit to operate the factory gauge.
Are there any after market "plug n play" fuel gauges?
Did not plan on hacking up the cell and putting the stock pump in.
What do most people do about a gauge? Just keep the tank topped off?
Thanks, I am a newb on fuel cells...
You can fit an aftermarket gauge into the whole in a yj dash with just a little bit of shaving on the inside of the gauge opening. You can get several aftermarket gauges that work with that sending unit.
