vaughn
- Mar 21, 2005
- thomasville, nc
so 93 wrangler, 4.0 manual trans. no fuel at all. pump wont come on. checked all fuses, relay is good, checked pump, comes on hooked directly, check ground at tank good, unhooked up top and at filter, still nothing. pump will work when direct wired. pump is new. still nothing. before this had to switch key on and off a few times then it worked, now nothing. any help or suggestions. could ecu, or switch cause this.
