91samurai
- Apr 20, 2016
- Midland, Nc
I’m currently working on what will be my new tow rig and daily driver. A 2003 Chevy 1500hd quadrasteer. This truck was originally my dads that he bought in 2005 with 20,000 miles. He drove it to 142,000 miles in 2017 when it was in a wreck and bent the frame. While it was running I took my driving test in it and used it to tow my samurai when it was first built. I drove down to Florida with the trailer to pick him up and bring it back. The insurance company totaled the truck but dad bought it back. In 2019 dad had some health issues(he’s doing ok now) and decided that big projects weren’t his thing anymore. So the truck was hauled to my house and sat in the woods until I was ready to mess with it. Recently I have found myself in need of something to daily drive and the timing has worked out to start working on this. A couple weeks ago I winched it into the drive way and started cleaning the parts out of the bed.
I had to rob the battery out of my suburban but it started up and ran. It would move some but the right front wheel was locked up. In the wreck one of the pistons in the brake caliper cracked. I just pulled the caliper off so I could drive it in the yard with no brakes.
I’m preparation for pulling the bed I took the bumper and hitch off and unbolted the bed. The tailgate closed better once the bed was unbolted because the frame was so twisted up.
One of the reasons I was willing to tackle this right now is I just got the building setup at my house with some used lights and a used 2 post lift. I don’t have any pictures but I managed to pull the bed with some ratchet straps between some trees in the yard. Having a lift is such a game changer for getting things done quickly and after being an automotive tech for 4 years it’s hard to not get upset doing things on the ground and not having a good workflow at home.
I bought a frame from a 2004 2500 that had been rolled over. Even though I hadn’t picked it up I was ready to start taking the truck apart. I pulled the cab and rolled the frame back out the door of the shop. Then unbolted the vise from the fab table and rolled it under neath. I lowered the cab onto some blocks of wood and ratchet straped it to the table for good measure. The 4x8 table was the perfect size. Next I rolled the cab as far forward as I could in the building for more room to work.
The core support came off next followed by the engine and trans.
I winched the frame back in and set it up to start pulling the rear axle and fuel tank and leaf springs.
I’m about ready to roll this frame outside and start on my new one. There is a tight turn from the shop into the driveway so I’m thinking about finding a piece of square tube the same size as a hitch receiver several feet long and using it in the hitch of my k10 to support the back and wheel it outside
My new frame looks like it’s in good shape. The salvage yard included all the front suspension. But with 370,000 miles I think I’ll swap all of mine into it. I will have to try and straiten my transmission crossmember since the one for this frame wasnt Included. The only difference between the 04 and 03 frames I have found so far is the charcoal canister mounting location. So I will have to cut the brackets off and swap them out.
I knew the ac never worked great in this truck and after seeing it at work several times I was sure it had a clogged up orfice tube. But this one is bad!
The truck was well taken care of but I’m going to try to take care for some of the obvious ls engine stuff that’s easy to get to now. I will be getting all the broken exhaust manifold bolts out while the engine is out and it’s easy to weld nuts to the broken bolts. I’m going to change the o rings on the coolant crossover tube and the little block offs in the back as well.
