Full width xj
offroadin 88xj
winston-salem
I got a ford dana 44 front axle im gonna use the radius arm setup but was wondering if anybody could help me out im wondering about coil mounts and the radius arms any help would be great
use the radius arm coil buckets. just unbolt them rotate 180 degrees and voila
I got offset radius arm bushings that gave me the right caster angle then got brandon at rides to cut the end off of the radius arms and weld d.o.m tubing to them with a insert for hiem joints then just plated the unibody and welded the mounts
Yeah, if u r able to modify the stock ford radius arm, and mounts on the frame, it really is rather close to a bolt in swap
Samsung SCH-I510 tapatalkin 2 u
