Road_Warrior85
Member
- Jun 23, 2007
- Jacksonville, NC
Just so everyone knows, Performance Innovations is not the place to go to if you want an electric fan installed on your radiator. You will find yourself out of money as you will have to take your vehicle to another shop to repair the damage Performance Innovations will cause.
Recently I contracted Performance Innovations to perform a 4.0 I6 to 5.7 Hemi V8 conversion on my Jeep Wrangler.
On that contract it listed an estimate of the work to be done, this is a quote from that contract..... "Install a new 4-row highperformance aluminum radiator, and electric cooling fans."
Further down on that contract it lists a breakdown of parts needed for the conversion (i.e. motor, transmission, shop supplies). That breakdown of parts also listed "Radiator-$400"
That price sounds fairly decent for a "4-row high performance aluminum radiator"... Doesnt it???
Simple enough so far, right??? I guess not.
First of all, that $400 radiator, ended up being a $200 junkyard find out of a STOCK Dodge Ram.
In his defense, it was 4-row, but not so much high performance .
Sadly, the junkyard "junk" didn't work. It did not properly fit inside the Jeep and line up with the motor. Unfortunately for me, Performance Innovations was unable to make good on there contract, and I was left buying my own radiator. Which he then installed.
Now as for the electric fans portion....
Many people would probably assume that they where getting new fans installed on their vehicle. However, at not point did the contract specify anything other than "electric cooling fans". Therefore, nobody can be disappointed if the fans they get are USED, right??? I was anyway though.
Nonetheless, I had an electric cooling fan installed on my Jeep. Sadly though, it was improperly installed.
A. It was mounted poorly, and later detached itself from the radiator.
B. The detached radiator, which poorly fit in the Jeep, cut into the radiator and punctured it (because it was in fact mounted poorly)
C. The Fan no longer works. After only 1,100 miles of driving since picking up the Jeep, the fan has now stopped working, detached from its mounts, AND punctured my radiator.
Now that it is all said and done, I must buy a NEW fan, and I have ALREADY paid $125.00 to get my radiator repaired, and the fan PROPERLY mounted (too bad it doesn't even work).
Of course Performance Innovations will not be reimbursing me for the damage caused by poor work, simply because that is the kind of shop they are.
Here are pictures of the fine craftsmanship of Performance Innovations
