what bearing are you replacing?
and what specs are you looking for?
(bellhousing to block or actual torque specs on trans case)
be prepared, that thing is heavy.
i recently did one and it is a bitch to get everything lined up. i ended up using a cherry picker to lower the case onto the bellhousing.
I have the same transmission in my truck and was wondering which bearings your having to replace. And if this is something I need to be concerned with and at what mileage.
It is an 07 with 60k miles. I'm replacing the input shaft bearing. From what I can tell it is a common problem. I am adding the trans coolers to it to help and have also heard to overfill it by 1 quart thru the shifter. I am no expert though this is just what I've learned talking to southbend clutch and reading some diesel forums.I ended up carrying it to a guy close by that said he would do it for 200 labor if I brought the tranny to him.
