C.Berry
Bad News
- Aug 10, 2008
- Blacksburg, Va
I read the impco 425 bolts onto the qjet with an is that right?? How much you asking for the 425 and the adapter if ya have em???
Guess my ole beat up Qjet dont tickle your fancy huh lolI run an HEI. I've heard folks of running MSD. I don't think you need to change anything except that carb![]()
I plan to call you in a couple of weeks to get my set up.you have 2 choices on adapters. they make a adapter to connect quad to impco 425 if you can find one, which I may have. or put a alum. adapter on intake and convert to a holley pattern since a holley baseplate fits straight to a impco 425. I have 2 used kits if you need one.
yes they do. I have not known anyone personally that has use this type system. It is easy enough to configure thought I would think. Utilizing a electric lock off for the pane, and a electric fuel(gas)pump, with an on and off switch. The draw back here that I see is that you need two different timing set ups to run each. I suppose a person could change it manually as needed. Not sure if there is something out there to tune the timing on this type set up from in cab so to speak.
The dual fuel set ups I have seen on line, basically has an adapter that attachés the propane mixer to the top of the carb, so either can be used.
Maybe not much help there, but, is all I know
Ha yeah im gonna look the carb over before doing this i could have a leak somewhere?
K im thinkin of buying a NEW Q-jet instead of rebuilding old one... lol I like the carbs i have the late 70's 350 with the 750cfm qjet and seems to be a good setup for the pane to run on if its in good working order... well see ill start a thread on this chebby when it warms up and i get started on it so you guys can give me hell about keeping my Q-bomb haha thanks
OK Let me clarify, The HOLLY base plate will bolt directly to the Impco 425 mixer. The Q-Jet will not. Using a Holly Base plate will put the vapor inlet to the front, or to the back. In a SBC you will have to put it to the front as it is just too close to the Dizzy.Ohh ok i really feel like a newbie when it comes to this pane even tho its a extremely simple design... lol Ill look into the Q-jet plate so any auto parts store will have this adapter cause i would like to have the tubes out the side not the front honestly! I apprecaite the info
actually NO was assuming the mixer bolted to the carb!!! So the pane mixer will send gas and pane ughhh im fighting with the roch for nothing lol
