Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
My daggum new motor I just put in my truck not too long ago (I'm at 30K now) is rollin coal, feel like it aught to be a diesel
Does so at higher rpm's starts at like 2-2500 rpm and the higher I rev the more it burns oil. Been getting progressively worse over the last 10k or so, at the point where it burns about a quart for every 10 gallons of gas, worse when I'm towing (don't used OD so it stays in the higher rpm's) and I'm towing almost 50% of the time I drive the thing nowadays, have to keep a couple gallons of Rotella in the bed everywhere I go.
Dunno if any of this matters but just for info its a 350 block bored .40 over and assembled by a fairly reputable engine shop. Put 98 Vortec heads on it, 1.6 roller rockers, mild cam - with the 1.6 rockers gets about 4.88 lift on both sides
Its runnin same as always, haven't lost any performance, just burning oil like crazy.
Pulled the plugs, no particular cylinder indicates more oil in em than the others.
Anyway - do the higher rpm blowin smoke/burnin oil symptoms indicate that perhaps the valve stem seals are shot? The Vortec heads were the only high mileage used part I put in the engine when I put it together - over 200k now.
If not I'm assuming its an internal gasket or rings, just never messed with any valve stem seals before so figured i'd ask . . .
If I do need to slap some new ones on I heard the best way to replace em is to pull the plugs and pressurize the cylinder to keep the valve from dropping out while your replacing it, sound right?
