gear oil leaking
bad*news*cj5
Walnut Cove NC
Hey guys got a t150 trans in my cj5. I have gear oil leaking out of the top on the left side. I leaks out when you drive it. Does it mean that it is just to full or some bigger problem?
Not too familiar w/ this but how much did you put in. I had a friend that could'nt get the fill plug out of of his manual trans and filled it through the top. He put too much in and it done the same as yours. I think manuals only require you to fill to the fill hole.
You only fill it to the fill plug hole. If you overfill it, it will create excess pressure inside the caseand blow out your seals.
