gear pattern
Ben West
rock corps
candler nc
this is my first try at setting up gears. have a look and let me know what ya'll think of the pattern, and if i should adjust on it more. It looks to me like it should sit in the valley more but i am not sure.
Thanks for the help, Ben
here is the one i replaced.
it went out about halfway up mason jar, still got me back to camp without winching.
upgraded to a v6 third with a spool instead of the welded 4cyl third
If its within lash spec id run as is looks good to me
i have done several regears myself and am well versed in setting up,i feel from the picture that the pinion depth is a little bit off center . it could be the angle of the picture or my perception ,but i would shim the pinion more to the gear and add a shim or two to readjust the lash,it will run with that pattern with probally little effect either way, it may cause a small axle roar driving down the road or maybe a small reend vibration purely my opinion however and congradulations you seem to have a firm grasp on what is supposed to happen in there, many people never figure it out
