i was thinking of changing out my stock gears for some more for what i am running... i have a tj, 4 in lift, 33's and stock gears..what gear ratio would be better for what i have?
well depending on engine and auto or manual, I am going to suggest 4.56 that way if you ever decide to go a little bigger you will be able to.
However I will go ahead and give you the "don't dump money into the 35" speech. You might as well go ahead and swap it out before you invest money into and then swap it later. Even if you are convinced you will never go bigger, I still say swap to an 8.8 or a 44, cause the right gears, the "right" foot and 33s can claim your 35 if you aren't careful. Good luck. Either way I say 4.56
