marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
alright guys need a little help please. 02 TJ Gen 5 L83 6l80e, standalone harness, everything else is stock.
Alternator will not charge. We bought the relay kit that wires into the OBD plug (or ECU wires like I did), still nothing... doubler/tripple checked wiring and checked it with the LJ swap I did, same on both
Swapped alternators nothing
We have 2 ECUs both tuned by same guy, both work like they should but no charging..
Swapped ECU with the LJ everything worked the same but no charging??wth
Now it gets weird...ONLY using jeep harness for factory gauges (oil, temp, fuel, and battery gauge) to work and they do...but the fuse box behind the glove box had bad/higher amp fuses, so I replaced them with proper amp fuses and WTH, alternator started working. It worked for a month now but just the other day customer called and it's not charging again.
This is my 3rd swap, did a 06 LJ SAME EXACT platform to the tee and his works perfect..nothing different other than factory harness reworked but we've checked and double/tripple checked harness from PSI and all checks out.
ANY help much appreciated, thank you
(what really confuses me is why the jeep side of this Jeep affected the alternator in the beginning?? I didn't care then, neither did customer, cause it got it working lol, but now that it's quit, I feel like we need to solve the issue of why it won't charge on it's own "chevy" side of the swap...like the other 2 swaps I've done.)
