- Mar 10, 2005
- Hooterville (24171)
Powers been out since 0900 yesterday, so connected the genset up and life was good!
Genset - 3000W(3KW)/peak of 4200W(4.2KW) with 30A breaker on the 240V side, and is back-feeding the panel thru a 40A breaker (was existing oven breaker, no longer used)... and yes, the main is open/broken so as not to back-feed the powerco's lines
The only things on right now are 2 fullsize refrigerators, and handful of *LED* lights... but it will *NOT* pull the pump (on a 20A breaker) or even support a vacuum cleaner!
All other 240V breakers (AC, water heater, etc.) are off...
As best I can tell the fridges are pulling 1200W each STARTING, but should be <1000W mark, combined, after that... leaving 2000W for the pump. I know that motor loads are higher, but... The previous owner ran his pump (150' deeper), 2 fridges, 1 freezer, and likely more lights off the same genset.
Is this just a case of not enough balls (watts) to run everything?
