RatLabGuy
- May 18, 2005
- Churchville, MD
This is actually for a lawnmower but I figure the principle is pretty general.
Having a hard time w/ a fuel connection that is leaking. Carb fuel inlet has a barb, a short rubber hose (1.5"?) connects this to a hard fuel line. End of line is slightly flared.
The original hose melted due to a fire (old lady next door never cleaned under the hood of the mower... years of dried grass caught fire...) so I replaced it. Guy at the local shop swore it was just standard 1/4" hose and gave me some (.250 ID .440 OD).
It has the typical springing hose clamps on both ends that you loosen by gripping w/ pliers.
However the hose dosn't feel super-tight on the barbs, nor are the clamps super tight (only takes a little spreading for them to slide around). It leaks when running.
What tricks are safe in this situation to tighten it up? I'll probably replace the clamps but honestly they look pretty decent. What about wrapping the hard lines in either yellow teflon tape or electrical tape? Maybe also a wrap or two outside the rubber beneath the clamps?
