- Mar 20, 2005
- Morganton NC
OK, this may be long.
Acquired a 89 XJ. I have never owned one, for that matter, never owned a fuel injected Jeep before. Yeah, I am still in the dark ages! It has a 4.0 with a 5 speed.
First off it doesn't run. I am pretty unsure of what to do to make it run, like I said, I have only owned one fuel injected anything, and have done little work to it. So, with that in mind. I charged the battery yesterday, and turned it over. With just the started and old as the hills oil in it, it built up about 40lbs of oil pressure. It has the rail system on it, not throttle body. I saw where there was a small tire valve looking piece in the side. I took off the cap and pressed in the release, and go a very small spit of gas. I then had my son to turn it over, and I pressed it in as he turned, and no more gas. So I assume it's a fuel line, pump, electrical, filter type of issue. I was told that at some point it was supposed to have been leaking gas. So with that in mind, any suggestions on what to look at first to track down the problem will be appreciated.
Ok, to move on to the build. This will be a budget build. So far investment is Zero, outside of the cost of fuel to go get it. Yes, it was free. I have located a set of CUCV one ton axles, 14 bolt rear with a Detroit, and a Dana 60 front with limited grip, for a $1000 bucks. This is for my son/wife to drive, with my son footing most of the funds for the build.
I have always heard that the frame or unibody on these things are one of the weak points. I am open to suggestions on what to do about this. One idea I have is putting it on a blazer frame, that I already have. I have seen one, but have never really looked at it to see how/what he did. I actually think he bought it that way. My reason for doing this is to give a good place for mounting an exo cage. Axles will be for the most part bolt in. I can run stock springs and with some fender trimming and run about what ever tire size I want. Beefy front and rear bumpers will be a lot easier to build, mount, and stronger. Thoughts on this welcome as well.
I think I read that the output shaft on my tranny is a 21 spline. I want to run a Dana 300 so an adapter kit will be necessary. Or, would it be more cost effective to fine a 23 spline 5 speed tranny? Again thoughts appreciated.
High steer/crossover arms will be installed, already know where I will get those. I know the frame on the Chevy will have to be re-enforced. Has anyone ever put a CJ style box on a Chevy? Only reason for this consideration is I can tap a CJ box for hydro assist. But, I am not sure about the shaft clearance and so on. Comments welcome
Ok nuf of all this. I will add more as my thoughts, and questions come to mind.
ya unibody weak point- do the doors open & close well? If so your jeep is still probably straight other than door hinge pins poor alignment of the doors & opening is the first sign of a crooked unibody-under the cherokee you will see what will look like 2 frame rails they are actually pressed into the bottom pan of the unibody it will stiffen the entire structer if you box these in with 3/16 plate with 1" holes in the plate about every 6 or 8" on all 3 sides then rosette weld (plug weld) the holes to the unibody & stitch the seams this will also give you good attachment points for a home made longarm kit to hold thos big axles- when & if you do this make sure you dont forget about the crossmember I would weld & extra piece of 1/4 plate where needed & drill & tap thru both 1/4 & 3/16
