Falko
- Mar 20, 2005
- Winston-Salem
The head of the bolt has nothing at all to do with the tension you can apply to the bolt via torque.
Thread pitch does have to do with the applied tension per applied torque, but in many cases is deemed negligible for real life purposes, the variance in torque wrenches is at times larger than that.
Fine threaded bolts do have more "holding power" due to the fine thread pitch creating more surface area (stress area) to divide the stress along the threads, but this is not related to the tension it will hold, as it should be assumed the material you are threading into meets or exceeds the tensile strength and therefore thread shear strength of the bolt threads. If not then your tension and subsequent torque values are governed by the material to be threaded into, not the bolt itself.
The reason the torque values for a fine threaded fastener tend to be higher, is because for a given bolt diameter, a fine thread has a larger minor diameter than a coarse thread (easy to see by looking at it). The tensile strength is determined by the minor diameter of a the bolt, as that is where failure will occur.
The finer thread pitch simply allows more radial distance to "fine tune" the tension on the bolt.
So much wrong in this post... I dont have time to go through it right now. Explanations comming later if others dont beat me to it.
ops: O -
