Not stock... You can have a ford retubed.Do they make HP dana 60 front ends with a passenger side drop?
Keep the pinion brake for the parking brake...I'm still debating on whether to do tons or 2.5 tons....I found a DIY disc brake conversion for the 2.5's using Ford B700 rotors and Ford F550 calipers which should only cost around $600 an axle, only issue with the rocks is that in NC there is a law that you MUST have a E-brake and I haven't found any threads or info on how to set up one on rocks.
Until the 4 cylinder blows up cause of the strain from all the weightAn indestructible mall crawler toyota
