Now that we had the body on, it was getting time to put the drivetrain in. In the prevoius rig, I ran a TH350 trans with a NP203/205 doubler. While I never had any internal problems with a TH350, I couldn't keep the case together. The decsion was made to go with a TH400, they're a lot beefier in the rear part of the case and have 6 bolts holding the transfer case to the transmission. Unlike a TH350 that has 4.
A lot of thought was put into what to do for a transfer case, but at the end of the day, the decsion was made to keep to the NP203/205 doubler setup mainly because it was the most cost effective solution, damn strong setup, and the gear selection worked well for my style of driving. 4 to 1 for crawling, 2 to 1 for trail crusing and hill killing. I decided living with the extremely heavy wieght and long length were worth it. Also, the doubler was one of the few things I had never broke and that says something with me driving! The only issuses I had out of it was the front output would jump out of gear while i was engine braking going downhill. Based on research, I found it was either the shift fork or the enagement slider. Both were ordered to be replaced before I tore into it. Once I pulled the front output bearing retainer off, it was obvious what the problem was. The snap ring on the front output bearing had deformed. Luckily, that snap ring happened to be the same size as a Muncie M22 front input bearing snap ring, which I had several of from my drag racing days. I went ahead and installed the new shift fork and slider just to be on the safe side.
One other issuse of going from a TH350 to TH400 was the change in transmission out put shaft spline count. 27 for a TH350 vs 32 for a Th400. That wasn't a problem as I had a 203 range box with a 32 spline input I had been saved for just this occasion.
Now I just had to find a TH400 transmission. After doing some research on Off Road Designs webiste, there are 3 ways to get a NP203 bolted to a TH400. The shortest is to use a TH400 that had a NP203 behind it from the factory used from 77 to 79. That's a darn hard transmission to find and I had zero luck after a month or two of searching. The next shortest was to use a Th400 that had a NP208 or NP241 behind it. Going this route ment that the adpater bolt pattern had to redrilled on the NP203 from the GM Figure 8 to the more common round 6 bolt pattern. You lose one bolt when going to the 6 bolt pattern but ORD's website said I wasn't an issuse so that's the route I went.
Now that I knew what version of the Th400 I needed, I had to find one. I searched craiglist for a while and couldn't find what I was looking for. One day while on break at work, I checked Pull A Parts webiste and it said they had just gotten in a 89 2500 truck so I decided to go check in the morning once I got off work. Sure enough, it was a 4x4 with a TH400 and a NP241! I grabbed my tools and when back the following morning and pullled the transmission, along with the NP241 for
@Anthony . That was heavy wheel barrow to get out the door. Think I gave just over $100 for transmission so I was pretty happy about that!
