Golf Cart
I will be using a engine/tranny from a 2wd 4wheeler, it had IRS so i will be just turning it sideways and the tranny will be like a tranny/tcase. going to have the drive shafts go where the CV's went.
Well... come this sat i will be heading down to Jacksonville FL and getting a lot of work done to the golf cart, the frame will be all welded up, the body will be on there, and the engine mounts should be built.
Back from FL, golf cart frame is about 95% done. got the engine mounts on there also. also picked up to more tires for it. Pics will be tomorrow .
Here are some pics of the frame. I still need to finish up the floor section and also add the front hoop that will hold the front of the body on.
Motor Mounts
My other two tires I picked up
I still have to trim the rear but this should be close to the ride height, it might be a inch or so taller when done. remember these tires are 31x15
and the body bolts onto the frame. I only have 1 bolt on each side for right now, but when its done it will have 2 on each side.
Got the engine installed, hooked up the wiring harness (PITA), looks like i will have to do some work to the harness to get everything to fit like i want it. then I just set in the golf cart making vvvvvvvvvvvvvvoooooooooooooommmmmmmmmm sounds for the rest of the night. what fun.
I have a question. Do yall think changing out the gear in the axles will help when it comes to the power? I just want to make sure i help out that 280CC as much as i can. and if so, which ones should i go with. the 4.57 or 5.38 ?
Ive had a few ppl tell me that the coil overs i have will be to soft for this. so i was thinking if they sag to much, then i am thinking about getting a set of Monroe air shocks to replace them with... any thoughts on that?
well the project is on hold for right now.. some one put sugar in my wife's gas tank so i got to get that fixed.
Pics from today
a rough idea of how my coil overs will be placed.
I had to do this to keep me happy.. lol
idk if i posted this or not, but here is the engine.
the drive shaft is going to hate me...
a idea of how it will look (this is the cv axle from the 4wheeler)
and this is how far back i will putting the rear axle.
Here is a idea for a drive shaft I have in my head, its a 2 part drive shaft. with the first part being the CV axle from the 4wheeler, then some type of adapter plate with a shorten zuk axle.
I was also throwing around the idea of using the hub with the brakes from the 4wheeler so i could have some type of brakes, its that or doing a pinion brake. eather way i will be using a hub to keep the 4wheeler cv axle in place so when i flex it wont pull it out of the tranny.
I will be cutting where the red line is so it doesnt get hung up.
some more pics to give ya the idea.
nothing new to post.. but.. i talked to Ballistic Fabrication , they said my parts will be shipping today. but my order over at Northern Tools ( Thats where I got my links at ) still says "Pending"... Can't wait for these parts to get in so she can sit on her own weight... well.. i still need to get one more rim for it... but at less the back will be sitting on its own weight soon.
well my parts al'ready shipped, i haven't had any problems with them yet *knock on wood* but this is only the 2nd time ive ordered from them
Here is the front, just got to install the coil-overs.
And the rear, the coil's are the front's from a Sidekick
