I am looking to get a goose neck trailer, to pull my Xterra w/. Anything i should look for? I have bought a Kaufman trailer b4. My truck is rated to pull 9500lb, my truck is bagged in the rear w/ air lift and i have a brake controller. any help is appriciated.
Look guy How about letting us help you?
What is you tow rig that you have bagged and why do you feel the the need to talk about the max rate of pull and air lift, bags and brake control without telling of the truck, when your real question is looking for a trailer.. Is It a Honda, or a small truck?
Back to your real question, Don't know of many builders that will build a Fifth wheel or GN with 4k axles if it is not 3 axles. Most are going to be 5200 or more..
What you Know is that you Truck will tow 9500 if that is true, now you need to find out what the weight of your off road rig is then you will know how much of a trailer you need and can tow. I have found a lot of GN trailers that are in the 4k to 5k weight and if you have a buggy in the 4.5k that could put you at your limit.
A tag can be as little as 1800 lbs
Have you ever towed any real weight with your truck to see what it would feal like and if you like it? That would make the difference if you go with a GN that puts you at 9500 lbs vs a tag that's at 8000 lbs or so.
Ok What I would do, If the tow is 9500lbs its maybe a 1/2 ton truck or something like that.
I would keep the weight as light as I could and go with a tag in the 18' to 20' range if you wanted to put a tool box on it and to make sure you can move it to get the ball weight you want. I would go with 4000lb or 5200lb axles as they don't add any weight other then a little for the tires. They will hold up longer, tires will be better and should be more trouble free. Other then that get a normal trailer that is built with beams or channel and not angle it will have less flex and be more stable.
I would not go with a GN because of all the extra weight in the GN hitch and the fact that the overall weight will be more. Also most are built in the range of 20' being the smallest but you don't see many and 24' to 30' being what most build. Now a builder will build anything at a cost.
Yes if you tow long trailers and weight a GN or 5er is better but for a 18' to 20' you will have no problem and it will be even better with a WD hitch....
I have towed this trailer all over with no problem and its 25'-- 31' +- total
And this one is a 20'-- 26'+- total and the only problem is the onlookers
There you go my 2 cents...
