Grand Cherokee WJ build
GuerillaWJ
Monroe, NC
This Jeep was purchased Feb. 1, 2009. This is the list of mods I have done since then with a few pictures of the build, if you have any questions feel free to ask.
- MOD LIST -
2010
IRO Critical Path Long Arm Upgrade
IRO Rear Lower Control Arms
IRO Front & Rear 4" Lift Coil Springs
IRO Front & Rear Nitro Shocks
IRO H.D. Adjustable Track Bar
IRO Front & Rear Extended Sway Bar Links
Tenneco H.D. Dual Steering Stabilizer
IRO A-Arm Spacer
IRO 3" Cat-Back Exhaust
Magnaflow Hi-Flow Catalytic Converter
Custom Rockers Built by Carolina Truggies
285/75R16 GTRadial All-Terrains
3' Firestik Antenna
Kidde Fire Extinguisher
Cobra 25 LTD Classic CB Radio
10% Window Tint
2011
ARB Air Locker 30 Spline (Front)
ARB Air Compressor
IRO WJ Front 30 Spline Chromoly Axle Shafts
IRO Dana 30 Inner Axle Sleeve Kit
IRO t-case skid plate
IRO front lower spring retainers
Spicer 760X U Joint Conversion
SOLID Diff Cover
Custom Dana 30 Truss By Carolina Truggies
Kevins Offroad Incline Bumper
BFGoodrich Mud Terrain KM2's
High Clearance Front and Rear Fenders by Carolina Truggies
PRP Podium Racing Seats
Custom Mounts made by Carolina Truggies
An inner cage will be started by Carolina Truggies hopefully in August so check back for updates. I will post pics of the cage being built and installed along with by 5-point harnesses.
