RenegadeRestorations
- Dec 10, 2021
- Kannapolis,NC
Anyone have any experience swapping in a 4L60e in a Grand Wagoneer? Also looking to do efi. What issues did you have? Did you use Jeep or GM transfercase?
Hey, hey, hey…. I resemble that comment.shitty 4l60e
I daily one.Hey, hey, hey…. I resemble that comment.
As @Bebop mentioned, he'll be much money/time ahead and you'll be headaches/greyhair ahead going with a Terminator... more robust ECU & more features than Sniper360 engine. Customer wants the 4L60e. He also wanted a sniper kit. The one with an in tank fuel pump. I called Holley and they couldn’t tell me if pump would work with plastic tank.
Those TH400 were special units with a BOPC bell-housing pattern which doesn't exist in a 6L/8L.So my random thought is: didn’t some of the early GC have a TH400 trans? (GM trans)? How hard is it to put in a 6L/8L and adapt it with a trans controller to the “stock” tcase??
Drive shafts, yes but massive work,
Good to know, that's a great idea.Also, and AW4 out of a 4.0 cherokee will bolt to a AMC v8. They also have factory TCM's that are pretty easy to integrate.
As long as you keep a good trans cooler on them they take a serious beating!! I lost a cooler one time and smoked the pump and front seals. They put a new pump and sealed the trans up and I beat the snot out of my wonton XJ for several more years.Good to know, that's a great idea.
And this trans is tough as nails too.
Definitely.As long as you keep a good trans cooler on them they take a serious beating!! I lost a cooler one time and smoked the pump and front seals. They put a new pump and sealed the trans up and I beat the snot out of my wonton XJ for several more years.
A bud has a legit 450+HP stroker in an XJ (or what's left of it) and beats on it like a Jersey loan-shark... he says the AW4 and 8.8 are the only things gone undamagedAs long as you keep a good trans cooler on them they take a serious beating!! I lost a cooler one time and smoked the pump and front seals. They put a new pump and sealed the trans up and I beat the snot out of my wonton XJ for several more years.
Since the AMC V8s are *externally* balanced and the 4.0L *internally* balanced, at the least pulling the single counterweight off a donor 360 flexplate and afixing onto the AW4 flexplate (have done this with TH-400 flexplates for non-factory combos)? Or maybe it ain't far enough off to matter?Definitely.
You'd probably need a custom TC or flywheel to mate the AMC engine to AW4 TC. Or do they bolt up ?
Couldn't you just redrill the 360 flexplate for the AW4 converter in this case? That way the rotaing mass stays the same as the AW4 TC doesn't have counterweights.A bud has a legit 450+HP stroker in an XJ (or what's left of it) and beats on it like a Jersey loan-shark... he says the AW4 and 8.8 are the only things gone undamaged
Regardless, it's been done repeatedly LMGTFY - Let Me Google That For You
Appears that's 1 way...Couldn't you just redrill the 360 flexplate for the AW4 converter in this case? That way the rotaing mass stays the same as the AW4 TC doesn't have counterweights.
I'm 99% sure the converter bolt pattern is the same. Seems all AMC has the same pattern.
This is good conversation for an OD AMC hot rod project!
Gremlin, stroked and injected 401, AW4, narrowed 60. Pimp.Good to know, I'll try to remember that, might be useful one day.
