Yotaman2008
- Jun 8, 2009
- Robbins NC
In good shape for its age and hours, 926 hours. Runs good and mows good. Good tread on the tires and hold air. Lights work, changed to led pods. Replaced carburetor 2 years ago and only run non ethanol fuel. Put plugs in at the beginning of fall. Will come with a set of gator blades as well as high lift blades on it now. Only known issues is it has a small oil leak, I feel it’s the lower main seal but not sure. It has an idler pulley going bad, makes a roar but it’s been like that for a few years, never gotten worse. Last it is a dual tank mower, will hold 10 gallons but the right side tank the pickup seal is busted so I just use the left tank. In Robbins nc text 9106390814 asking $1600
