"grease car" SVO kits
The kits are pretty much the same stuff. I've been piecing mine together. My truck came with a 65 gallon tank in the bed...but I've purchased everything else (aux fuel pump, filter, 3 way line, heater, aux fuse block...) localy or on e-bay. I think I'm gonna build mine for less than $700.00. I've figured, 2 trips to Callalantee, 1 trip to URE and my trip to Camp Jeep this summer will pay for it...
I'll try to get a write up about my install up soon.
Well, it's got the hose-in-hose...good.
Doesn't use the pollack valves...good.
You certainly need more parts before you can run it though.. temp gauges so you know when you can switch over, switches, panel, etc...
http://frybrid.com/kittest.htm
^^ quick comparison
Kit Includes:
Fuel Valves (2)
Wire Harness & Connectors
Fuse and Harness
Lighted in Dash Fuel Gauge
Lighted 3-Position Switch
Heater Hose
Window Decal
Instruction Manual
5 Micron Bag Filter
Hardware
Hose Brackets
Heated Fuel Line
Fuel Hose
Hose Clamps
T-fittings
Large Hose Clamps
Heated vegetable oil tank
Heated 10 micron fuel filter
Temperature Gauge $65.00
Monitor your vegetable oil temperature by adding this digitalgauge to your system.Range is 0' - 300' F. Comes with all the hardware you'll need for installation. Display Color
Red Red Green Amber
I was thinking that i could just put the temp guage, fuel guage, and then an EGT in one of those three pod pillar guage mounts.
OK, but there's been discussion about the filter clogging very fast because of the way the return is plumbed, and also the length of purge time/method..
You could add another valve to change the purge method, or live with your finger on the button for a minute or more at a time.. :p
