carthief007
Member
- Feb 21, 2009
- durham,nc
well at operating temp my ford decides to just raise the rpm's up to about 1200 all by itsself...351 FI,almost positive no vacuum leaks(just fixed the only one i know i had).
other issue...will run great on startup...gets to operating temp(185-190),will sometimes just cut off...new plugs wires cap rotor fuel filter air filter and ignition module...tested coil and it pulses great....other times it will run great,i think the gremlins have taken over my ford
NEW INFO...codes...
114 IAT sensor out of range - IAT
116 Engine Coolant (ECT) sensor out of range - ECT--not too worried bout this one,manual guages
118 ECT sensor is/was high or open - ECT
212 Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems ---new ignition module
327 EGR feedback signal is/was low - EVR or PFE
621 Solenoid/circuit failure - shift solenoid 1 - Transmissions ---this is a new one that just popped up tonight...
NEW INFO...codes...
