Looks like the tube did a good job.
I sat down for about an 1 1/2 hours and did about half of one 34x9.5 TSL. Keep in mind I had to stop once and let the iron cool down to put in a new blade. So there was about 1 hour of grooving total.
What I learned:
1.)The Iron gets TOO HOT if you leave it plugged in the entire time. At least too hot for my liking. There was smoke coming from the rubber I was cutting out. So what I have started to do is plug it in till it gets almost too hot then un-plugging it, groove some then plug it back in and un-plug it again. Repeat.
2.)Cutting out wear bars is different than regular grooving. Regular grooving like cutting the V lugs in half only takes one swipe per lug. Each wear bar takes 3 horizontal cut, 2 vertical cuts, plus some cleaning up of rubber strands.
3.)At least in the case of the TSLs it would be good to have 2 different blade/head sizes. The #4 head for between the outer lugs and the v lugs (white arrow) and then a #6 (or #8) head for the actual wear bars (red arrow):
You would have to go through first and groove out all the areas with the #4 head/blades, change over to the #6 head/blades let it re-heat and then groove out all those areas.
4.)Don't expect it to look that great considering you have to match up 3 cuts (which would change if you had the #6 head/blades). But its not meant to look good, but be functional.
