Can you see the wires on the good side? If not try to carefully cut open the tape covering the wires. That mat help you figure out the side that was cut. One wire may be a ground, may be why there are only 3 wires coming from the light.actually have stock lights. somebody cut pigtail off of passenger side before i got it. and i can't get it to work. i got the brake light and running light and backup lights working. but no turn signal. driver side has pigtail, works great.
This would be a big help. OBXBronco, could also use a test light to see when each wire from the harness becomes hot. Have a helper engage each function, while trying each wire.I'll get my FSM out tomorrow and try to get you all the connector pinouts...might help?
Greg
maybe, but I think tag light runs off of tail light bulb
here's what wires i have. violet/black - black/yellow - red/green - and looks like red/brown. i know the violet/black is the backup lights. i have the black/yellow and green/red hooked to my light. stoplight work, backup light works, running lights work. no turn signal though. i've tried switching wires, but no luck.
or where do i hook the green/red?
