Harlin 10-21
had a great time. good to see all you guys. i must of done something wrong because i didn't break anything.
Suprised that you didn't break............ When your 52 was under that rock on DAMNATION and you were on the gas................ That cummins was determined that something had to move. Your tire was moving that rock pretty good.
Fun weekend.
I've never seen LD that dry. Was everything that way?
no...there was a freaking monsoon thursday night. Fish Fossil was a sloppy mess all weekend. We also got lead to a new trail('Underestimated') late Saturday night/early Sunday am. that was quite muddy as well, we got off it and back to camp around 5:30 or so Sunday morning. No one (3 of us ran it) broke it was just a nasty trail.
Is that the new one off the right side of 10?
A list of carnage from our group
3 birfields(2 broke at the exact same time)
1 Aussie Locker
1 Lock-right
1 r+p
1 transmission or Clutch(not sure yet)
1 head gasket(still ran good all weekend though)
1 clutch master cyl
1 clutch slave cyl
2 headlights
1 voltage regulator
2 brake lines
1 power steering setup--on the way out on the last day driving normal!
1 broken bead...on an H1...hum, bought a set of tires and wheels already assembled and no pvc insert as advertised, someone is getting a phone call
1 CV
1 driveshaft
not to bad considering we were there for 4 days:shaking:
oh...and about the foldable cages...just ask Tim what they can take....he didn't see the Mangler(shawn) behind him(go figure) and backed up his tire, onto his bed, up the bars that go to the back of the cage and then to the top of the cage....BTW Tim is Firetoy:fuck-you:
Add..
1 shock mount - Justin's welds held without issue...ripped a section out of the frame.
1 4cyl radiator
1 Aussie Locker
1 Lock-right
1 r+p
1 clutch master cyl
1 clutch slave cyl
2 headlights
1 voltage regulator
2 brake lines
1 CV
1 driveshaft
not a bad list...we had:
broken detriot (go figure) in a 60 front end
broken spider gears in a welded 60 front, shot the spider gears through the housing(yes the cast housing, not the cover)
inner/outter/joint on a 60 front alloy shafts
R&P in a yota
driveshaft issues in a yota buggy
alternator and battery
hub bolts in a yota
tranny in the FJ45
high steer bolts in 60
I got away with a pin hole in the radiator that water weld took care of.
I saw A LOT of stuff broken this weekend.
