Long story short I bought a used 9.5kW Kohler natural gas standby generator off Craigslist a little over a year ago after yet another big afternoon thunderstorm knocked the power out and I had to run out and fumble with my 5000W/6250W surge portable gen to get it hooked up so we had the well pump, lights, and ceiling fans to run through the bathtime/nighttime routine with our little boy. I poured a pad behind the house a couple months later but only finally connected the natural gas and wired it in to the panel last week (added a breaker and installed an interlock, no ATS because it wasn't worth the hassle). As expected the three-year old 2.5 ton Lennox condenser unit would not start up, blinked the lights and dropped the voltage enough to reset quite a few things in the house, trip GFCI breakers, and reset the HVAC. So I went looking for anything that could do a soft-start on the compressor motor (it has a nameplate locked rotor of 78A, generator is rated for 39.6A, clearly not enough for a full-voltage start).
Lo and behold I find a company called Micro-Air that builds these Easy Start soft starters for home, RV, and Marine AC units. I ordered their 368 Series sized for my unit, it showed up in two days (FedEx actually came through for once) and I installed it on Tuesday. It runs five "learning" cycles to figure out how much it can throttle the start and you can use a rudimentary phone app (it has Bluetooth) to track the reduction. The first start clocked in at ~30A, the unit iterated down to where it leveled off at about 24A to start the condenser. The way it is connected the fan on top of the unit starts immediately (as normal) and the compressor comes in a very short time later after the fan is already rolling so you do not have both starting at the same time. The unit is permanently wired and operates all the time (not just when you are on generator) so like any soft start application you do get the added benefits of reduced contactor wear and reduced electrical strain on the motor. It also starts up a bit quieter than it used to.
After it finished the learning cycles on utility power I started the gen, transferred the house power, and let the AC start up whenever the thermostat called for it. I know the power roof fans (3) were running already and I am sure some other thing were running in the house. The condenser unit fired up without an issue, no light blinks or other issues in the house. My Powerware 5125 UPS for my networking and computer equipment detected a slight dip (there was a blip from the audio alarm) but everything worked fine. I checked the starting current at about 24A so it has slashed the startup surge to about 5800W which is well under the 9500W I have available. I still cannot run everything (we have electric water heaters, electric range, etc) but at least for power outages we can use the AC, well pump, refrigerator, freezer, lights, ceiling fans, TV, computers, etc and still have some margin left over with a machine that is half the size typically sold to run home AC units. Technically speaking I probably could have started up the AC on as small as a 6000W portable generator so I might attempt it with the portable unit at some point and report back.
Best deal I found on them was here: Marine Air Conditioners - Soft Starters - WATER YACHT SOLUTIONS
There are also units from ICM and Hyper Engineering that I read some reviews on; they do the same thing and folks have reported good success. I liked the bluetooth and diagnostics available with the Micro-Air unit that you do not get with the other ones but they are less expensive.
