- Mar 18, 2005
- Reidsville, North Carolina
I have been thinking about a diesel tow rig to replace the Jeep J20. I only achieve 5-6 mpg towing and have a small gas tank so fill ups are often. I also am not getting quite the power I would like for towing in the mountians and the Jeep runs hotter than I like under a hard pull. The ride is quite stiff as well.
I have found a '92 or '93 Chevy 3/4 ton with the 6.5 turbo diesel in fair shape. Not sure of the miles but it runs good. It does however pump all the water out of the cooling system. So at the very least it has a blown head gasket. maybe a cracked head? No water in the oil though.
I also know the transmission works well but leaks fluid and would need to be rebuilt. I think it is a TH400 but not sure.
Otherwise truck is in fairly decent shape for one that old.
I can get the truck for around $2k , would it be possible to stay around 2k or less in repairs and still end up with a decent, reliable truck for towing?
Experiences with the 6.5 turbo ?
I cannot afford a 90's or newer Dodge or a Duramax from the prices I seen.
All experience / thoughts / suggestions welcome.
Thanks,
Thanks,
