Having the selection makes it easy to mix and match......
Dan Fredrickson
Sacramento
To get the combination needed for your project......
12 different Spring Perches
9 different Spring Hangers
6 different Ubolt plates
5 different Shock brackets
Shackle hangers available in any different width......
We can fit up your new axle or replace the old parts with some that will outlast the rest of the truck!
Our Chassis Link Brackets & New Adjustable 3 Legged Links
We are getting alot of new competition in the Link Bracket area so I thought it was about time I posted the obvious. Firstly I should say all of our Link Tabs & Brackets were designed to fit every joint, not just some joints, take a look at some of the Brackets becoming available and imagine trying to fit an EVO in there.... Here a couple of things we have been making for a long time, and for good reason! And something new too!
Our Chassis Link Brackets, made long enough to have a smooth transition for rocks to slide over rather than abruptly for you to hang up on. Also, with enough bulk and a ramp to add that protects your expensive joints and stiffens the Bracket much more than any other, obviously:p
Our 3 Legged Links, no better or stronger way to tie into the frame interior rails, 3/8" for the strength and with enough open area to never collect mud, they are available in Zero, 10, & 22 degree angles:D (zero & 10 degree shown)
awww.ruffstuffspecialties.com_gallery_albums_userpics_10001_normal_3legflat0degree.jpg
awww.ruffstuffspecialties.com_gallery_albums_userpics_10001_no36779e1961d33cb0a2c3f428704956eb.jpg
And the new variation, Adjustable 3 legged Link Brackets, they will be available in 3 weeks! Same as the standards but with 5 point adjustability! (22 degree shown)
awww.ruffstuffspecialties.com_gallery_albums_userpics_10001_adjustable_203_20legged_20links.jpg
