bmorton1981
- Dec 28, 2009
- Locust
Ignition Switch Removal? Heat Problem 1997 TJ
Ok, I got an issue if anyone can give me some pointers. I have a 1997 TJ. The heat works but it only blows out at the floor and the defrost. The vents where the most heat is received is not working, If I put the switch on the vent selections you can just hear the motor blowing hard like its working but nothing comes out the vents. ???? any suggestions on how to fix this? Thanks in advance..
Ok I have another Problem, My wife lost my keys yesterday and yes the spare was on the same key ring. I called and got a replacement cylinder and keys from Advance. I took the plastic column collar off and I can see the cylinder, Does anyone know the PROPER way to remove the cylinder? Please Help
