Ridgerunner
- Mar 21, 2005
- Fuquay Varina, NC
History
2 years ago I replaced the spider pop-it with a upgraded mutil port Spider do to a failed fuel regulator diaphram leaking fuel in the intake causing a p0300 code and running like crap. then it ran great
This last spring I replaced the Fuel pump as it failed. then it ran good again.
This last weekend I was driving it and had to hit the brakes hard at a stop light. the engine started missing and again the p0300 cam up. no matter what RPM it is is alway missing and sounds like it is running on 5 cyl.
So to day I replaced the cap an rotor just because and it had been sitting fo 2 days. I started it up and it ran Great and I was happy again (so was the wife it is her car).
so just to make sure everything was good I drove it in to town and back (about 10 miles) and when I was almost home I hit the brakes and the same thing happened. now it is running like crap again.
So I thought Brake booster vacuum leak. so I pugged the booster hose but no change.
The only other thing I can think of is maybe there is water in the tank from a bad batch of gas.
Th fuel Pressure is good between 56 and 62 and jumps to 62 when I accerate. It does not leak down when shut off.
any Ideas??
any Ideas??
