jerzsubbie
- Sep 5, 2020
- Davidson
This is my first solid front axle vehicle, just bought it 3 days ago, but have done about 350 highway miles already and noticed some uneasiness after hitting bumps or expansion joints. I've googled quite a bit and am pretty sure this is bump steer and i *think* I know why, but am not 100% sure.
Vehicle:
15 JKU 64k mi, 3rd owner
3.5" RC 2.1 lift with drop brackets & cam bolts (I know... dealer installed before 2nd owner purchased)
OEM track bar w/ RC riser at the axle side
OEM drag link w/ OEM pitman arm
RC dual stabilizer
The worst case was yesterday on my way back from Mebane, on I85. I was driving 75 on cruise control, hit a bump at the end of a small overpass, the wheel wiggled back and forth, cruise control abruptly cancelled, and traction control kicked in. It scared the heck out of me for a half second until I realized what had happened.
I grabbed an angle finder and got the following measurements:
Pinion angle - 1*
Caster - Driver 4.1*, Passenger 6.7*
Track bar (measured at bolt centers) - 3.9*
Drag link (measured at ball joint centers) - 6.5*
Clearly these two aren't parallel, but how much wiggle room do you really have?
Speaking of wiggle, without jacking it up, I didn’t notice any wiggle in any of the linkage joints on the front axle. Couldn’t really talk about the knuckle ball joints.
What would you guys recommend I try first to fix this? I'm guessing play with the cam bolts to get the caster to about 4.5* on both sides? Do I need to get something like the JKS drag bar flip with track bar bracket? I am likely going to rip out the suspension and replace it with something of much nicer quality, but want to at least get this driving better in the near term.
Take it easy on me, please
Vehicle:
RC dual stabilizer
Pinion angle - 1*
