carb
it is a 86 toyota with a 22r. engine set up - header , 9.7 copression pistons .30 over,gasket ported and polished head, with lc engineering street cam,lc engineering rockerarms ,and valve spring, also has 3 angle valve job. got a rebuild asian carb for it. its having a hard time starting and idleing ruff, want go down below 1000 rpm at idle,and when you drive it does fine until you come to a stop then idles around 12-1500 rpm.got to adjust choke all the way off to get it butterfly to open up then it want idle even after adjusting the idle screw.took all smog stuff off it. think its sucking air. you can spray it with carb cleaner around the base and it revs up. but ive changer the gaskets 3 time and still doning it. think my spacer might be cracked, dont know cant tell by looking at it. ran better when i had a holley on it but that truck wouldnt start when cold and the stock carb that came with the truck run good for a while then craped out sso got a new one. i cant tune a carb to save my life . so im at aa lose.
