HvyChevy
- Jan 3, 2012
- N Raleigh, NC
I am in need of some advice, here's my issue. I have a '78 Chevy 350 4-bolt with a quadrajet carb. I recently rebuilt the carb changed the gaskets and cleaned it well. She was running great, choke worked, 4 barrel opened and all was well....until....Last week I started having a little issue. The engine is having trouble starting cold, but once it starts it idles fine, sometimes it will smoke a little but i know the valve seals are prob on there last leg. The BIG problem is that if I give it hard throttle from idle it will hesitate then "catch up" and rev on up (sometimes it will stall completely). At first I thought it may be too rich so I have adjusted the idle screws, no change. I'm thinking, maybe ignition advance/timing, vacuum leak, faulty accelerator pump on the carb, the quadrajet famous "leaking bowls", or (as i suspect)the engine is just a piece of sh**. all advice is welcomed.
