Help! J-10 Locking Hub Disassembly!
Ray VanBuren
Shelby,NC
This is the first time I've had to disassemble my front hub(only had the J-10 two week). Need to replace my wheel studs. Can't figure out how to remove the pictured item. Probably on here somewhere, but in a hurry.
there is a large wire clip holding it in. Pop it out and sometimes you have to inset a couple of the hex screws and use them to pull out the piece.
Use the screws and the same picks or screw driver againist the outer hub to leveage it out.
Thanks everyone for their help. I finally found the mystery lock ring. Wheel stud replacement complete.
