What exactly does it do? The jeeps not running right wonder if it has to do w this not being on there
Despite being "new" (which it likely is just a reman, since they stopped making them in the late '80s), you may still need to tune it... float level, idle, etc...The jeep will crank up and run for about a minute and then stall out.
So are a lot of aftermarket carbs like quick fuel, but you still have to tune them to your engine. I've found debris inside the fuel bowl of brand new Holley carbs before. Every new carb I get gets pulled apart, blown out with air and looked over. That would go double on a reman.They claim the carbs are bolt on ready. Already bench tested, flo tested ready to bolt and go...
Sounds like it may have gotten trash in it.Once the carb was replaced it ran good a few seperate times. I drove around the neighborhood w it. Then it say for a few weeks and won't run over a minute without cutting off
Well yes it sputters out. Sorry for the wrong wordingYou said it cuts off pretty abruptly. Typically fuel issues will sputter and engine out. Electrical will give an abrupt cut off.
Could you have an electrical issue that is showing its head. Maybe coincidence in timing of carb swap?
When motor quits when will it restart ? If it doesn't restart quickly run it till it stops, remove air cleaner, look down carb and open throttle all the way quickly, if you see a squirt of gas you have not run out of gas. If you see a squirt then remove a spark plug wire from the easiest to reach spark plug and connect a spare spark plug to the wire and lay the plug on metal part of engine, have somebody crank engine while you observe the plug for a spark. Before you change parts I would do some troubleshooting. If it restarts immediately it's probably an electrical issue such as a loose wire, shorted wire, or bad switch.
