fbpd227
- Jan 12, 2007
- Smoky Mts. WNC- Sylva, NC
I need some good clear tech info, please! I have burned up 3- TF999's ( 32RH ) in just over 3 years! They SUCK ( with MY setup anyhow )!!!! I was wondering IF/HOW I could upgrade to a stouter transmission without having to buy a $1000 in adapters to put a GM auto in it? I am on a VERY poor man's budget- and will have to what ever I can to get this thing running again! I have paid @ $1200 for each rebuild- WHEN I HAD A JOB- and can't afford that route right now- so...is this possible/ easy- bolt up? to both the 4.0 AND the stock transfer case ( 1993 YJ ), I have heard something about relocating the crank sensor on the back of the 4.0 to the front - but that's all I have ever over heard? I am desperate guys! ANY and ALL help/ advice would SOOOOOOOOOOO appreciated!!!! Thanx- A desperate wheeler!
ps; also- from day one after each rebuild all the way through till they died- IF the jeep had been sitting for a few days, when I put it in gear it would go in "sluggish"- kinda like VERY slow to engage the desired movement (IE forward or reverse) is that a common problem to TF transmissions? I once had a FS grand Wagoneer and it also did the same thing....maybe I just have crap luck with TF auto's?!?!?!?!? LOL
